how do u set timing
Old May 16, 2007 | 08:41 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
how do u set timing
how do u set timing and total timing? i have a adjustable timing light to work with. i dont completely understand how to set timing with vaccuum advanced distributor. so please help me!
Old May 16, 2007 | 09:20 PM
83Chevy__Camaro's Avatar
Re: how do u set timing
get a vaccum gauge, unplug the vaccum line to the carb from the distributor and hook the vaccum gauge to it, hook up the power for the timing light, loosen the 9/16 bolt hold down on the dist, start the car and get it to warm up, then point timing light at the timing marker, make sure the dial is set to 0, then move the dist till its at the mark u want, tighten and drive and see if you like it
Old May 16, 2007 | 09:28 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Hooking up a vacuum gauge to the vacuum advance accomplishes nothing.
Point the light at the timing indicator down by the damper. Hook the clamp on an ignition wire (I use the #1). With the light hooked up and the engine on, pull the trigger. It will flash when that plug fires. When it flashes, the timing score line on the damper will be roughly in the area of the timing tab. Rotate the distributor either clockwise or counterclockwise to adjust the base timing.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
