Bad Fuel pump, or in wiring to it?
Old May 17, 2007 | 08:52 PM
taman86's Avatar
Car: '86 TA 305 F, '89 GTA 8
Engine: F 305 TPI, 8 350 TPI
Transmission: 700 r4
I got an '89 350 tpi. Car starts intermittently because fuel pump works off, and on.
If the car does start, then I can drive it fine for as long as I want to. If I try to restart it later, then there is about a 50% chance that it won't start, because there is no fuel pressure. Then if I wait for a period of time 1/2hour, or longer, then fuel pump works.
My questions:
If fuel pump is working off and on, then wouldn't it quit working as I am driving it, stranding me wherever?
What should I check 1st? I did swap in a used Fuel pump relay, and still getting same problem.
Can low Oil pressure cause this? Mine reads between 18 and 35 on my gauge.
I read on another post, that low Oil pressure can cause the fuel pump to shut off.
Old May 17, 2007 | 09:16 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Bad Fuel pump, or in wiring to it?
the pump could well be dying. its not too uncommon for them to act like your is.
to check to see if your getting power out of the relay, wire a test light up from a good ground to terminal A on the fuel pump relay. put the light somewhere you can see it from the drivers seat.
make sure to route the wires so that none of them can get caught or burned on anything.
when it won't start see if the light comes on when cranking, if it does come on then you'll need to look for problems with the wiring between the relay & the fuel pump.
if you find no problems then change the pump & pay close attention to the connector outside the tank & the wiring inside the tank looking signs of damage or overheating.
Old May 17, 2007 | 09:40 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
the engine will bypass fuel pump relay as soon as it sees 4psi of oil pressure,mine was starting with a bad relay,once engine is running,it kinda likes sucking the fuel thru a straw/with litle to no voltage,and then no restart,seems as if a restriction like a plugged fuel filter,except mine was real hard to start,once running had sporatic surging,after fuel filter change problem went away?
Old May 17, 2007 | 10:26 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The oil pressure switch does not over ride the fuel pump relay at any point during operation. At ~4psi, the pressure switch closes, supplying an alternate source of power to the fuel pump in case the fuel pump relay fails.
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Newguy91rs
Aug 7, 2015 09:51 PM
