Importance of CORRECT Spark Plugs
Old May 25, 2007 | 04:10 PM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 4:11 posi
Importance of CORRECT Spark Plugs in Vortec Heads
ATTENTION: This applies to Vortec and some aftermarket heads only not to "stock" heads.
I posted my situation in the Alternative Port Intake section, you can read it HERE . So I thought I would post a few pictures of what the WRONG and RIGHT spark plugs look like in the combustion chamber (difference between an ACDelco R45TS(taper seat) and R42LTS(long taper seat)). This will hopefully make some of you aware that there can be a huge difference in reliability and even performance for using the old "stand by" plugs.
The first picture is the outside pic of the plugs, top one is the CORRECT R42LTS and the bottom one is the INCORRECT R45TS (no L)
The second picture is of the combustion chamber this is where the difference is obvious the R45TS does not even break the plane of the combustion change, the electrode is in the threads for crying out loud. The R42LTS on the other hand is well into the combustion chamber as it should be.
The third picture is the same situation of the second picture just a different angle.
Attached Thumbnails Importance of CORRECT Spark Plugs-hsr-upgrade-013.jpg   Importance of CORRECT Spark Plugs-hsr-upgrade-007.jpg   Importance of CORRECT Spark Plugs-hsr-upgrade-008.jpg
Last edited by nedoss; May 27, 2007 at 12:04 AM. Reason: Specifying the cylinder head
Old May 26, 2007 | 03:23 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Importance of CORRECT Spark Plugs
of course those are the vortec heads the need the plugs for vortecs or fastburns hear the have pretty much the same chaimber
Old May 26, 2007 | 11:57 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You scared the crap out of me for a second - I always used normal R45TS plugs since that's whats called for by the factory.
You need to specify WHICH HEADS those plugs are "THE" right plugs for.
Vortecs eh? Ok, then for those of us not running vortecs, we can disregard this. Or.... which heads are those?
Old May 27, 2007 | 12:07 AM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
Thanks for pointing out I didn't specify which heads this situation occurred on, I believe I have resolved that issue now.
Old Aug 9, 2007 | 02:32 AM
Anomaly's Avatar
Car: 1987 IROC
Engine: 383SR
I just ran outside right now in the rain to check mine and sure enough im running Delco R45TS in my vortec heads!
THANK YOU
Old Aug 9, 2007 | 07:41 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Similar situation with the AFR Eliminators.
I have to run gasketed long plugs in them.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
