intermittent starter cracking speed ...
Old May 25, 2007 | 04:51 PM
tsibouky's Avatar
Car: 85 black on red t-top t/a
Engine: 305 h.o. l69
Transmission: t-5
Axle/Gears: borg w/ discs 3.70 posi
3 weeks ago i wanted to go cruising, but like the idiot that i am i fluded the enigne, whatever i removed the plugs dry them out but iwuz wroking slowly and the sun whent down so out of time and light i placed the plugs back in fingure tight and slapped the wires back on worng firing order just to get the car in the garage, so i did and well a couple of days agao i went to start her up she ran a little rough so i fixed the timing ( by now i have completley forgetten about finger tightening the plugs ) so i go cruising, driving and shifting hard, having fun, then i start back firing al sorts the car runs like **** and kept stalling, it must of stalled at least 30 times before i made it home, when i got there and parked i could smell the srarter from the driver seat, i let it cool down while i remembered about the plugs im a dumbass, regardless i got to crank and the starter would cracnk slow then fast then slow really slow the lights would dim out, i though batt, charged it tried again, nope maybe starter smelled bad, chnaged starter, nope same prob, maybe i fried the batt wires by overheating, chnaged batt wires, and cleaned ground, nope still smae prob, i have no multi meter but im pretty convinced that the starter is getting 12v and enough amperage from the batt, i think i may have fried a ground somewhere or something, if anyone has a next step for me i would apreciate it, and yes i have fuel rebuild starter new batt wires new batt and my prob is the starter cranks slowly for long and fast for short period of time to short to start ... help i want to drive car, very little time to work on it ...
Old May 25, 2007 | 06:05 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: intermittent starter cracking speed ...
Starter needs to be shimmed. its too close to the flywheel. The starter gear is binding on the flywheel gear.
Old May 25, 2007 | 06:29 PM
tsibouky's Avatar
Transmission: t-5
i did not put back the shims because i wuz in a rush and working on the floor sucks, but i have the same problem i had with the old starter wich had the shims on so i may have similar symptoms different problem, i will reinstall the shims tomorow i wanted to do so but i figure it would not solve my prob since i have the same symptoms .. thx for the awnser hopefully it will solve my prob ...
Old May 26, 2007 | 08:35 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Every starter/block is alittle diffrent. Some need shims some dont need them at all. Did you mess with timing, could be to far advanced.
Old May 27, 2007 | 09:07 AM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Have you checked the voltage regulator in your alternator?
Frozer!!!
Jan 19, 2024 04:55 PM
destroyerwes
Aug 26, 2015 08:17 PM
michealleger
Aug 26, 2015 03:29 PM
kyleb24
Aug 15, 2015 08:24 AM
86Base
Aug 8, 2015 01:34 PM
