im out of ideas ... help me for pete's sake
Old May 26, 2007 | 06:20 PM
tsibouky's Avatar
Car: 85 black on red t-top t/a
Engine: 305 h.o. l69
Transmission: t-5
Axle/Gears: borg w/ discs 3.70 posi
my prob is that my starter intermittently cranks slow and fast and starts to smoke very quickly, i cant get it to start i have a new batt, new starter, new batt cables, new starter cables ( fusible links and connections ) new ground wire ( firewall to motor ) i have fuel and spark, i shimed my strarter, i have proper firing order 18436572, i have power everywhere and signal everywhere i just cant figure out why my starter just cranks fast then slow then fast then slow, when i cranks fast everything seems fine just doesnt cranl long enough to start the car but when it cranks slow all the lights dim and flicker, ive changed everything going to the starter and the starter itself, i dont have some high compression motor its a stock 305 h.o., enough voltage and amperage should be going to the starter ... so what the !@#$% is my prob
Old May 26, 2007 | 06:25 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
Re: im out of ideas ... help me for pete's sake
had same problem one new starter problem gone. mine only acted up on hot starts
Old May 27, 2007 | 10:41 AM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Try another starter.......and make it a high torque model for good measure.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Jorlain
Oct 8, 2015 01:57 AM
TrevinE
Sep 14, 2015 03:20 PM
Nick McCardle
Sep 10, 2015 08:36 PM
