HELP! No oil right bank.....
Old May 26, 2007 | 01:52 PM
Zdaddy's Avatar
Car: 1987 Camaro IROC-Z
Transmission: T5 currently
Axle/Gears: 10-bolt Moser/Richmond 2.73
Just finish new build, installed pre oiler and w/ drill ran clockwise several times and oil ran out of all rockers on left bank, lifters pumped up all good, BUT, no oil on right bank and lifters still flat... what the heck!?!?!?
Please help.....
THANKS,
Brent
Old May 26, 2007 | 02:31 PM
2oldFbody's Avatar
Car: old chevys
Re: HELP! No oil right bank.....
I am assuming you are using a store bought pre oiler and if so I don't think
you will get oil on that side. If you look at your dist. at the bottom by the gear you will see a groove machined around the body, that groove supplies
oil to the other side of the block IIRC correctly. Take a junk dist. remove the
gear and the stuff on top and make a pre oiler out of that.
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
