rocker arm stud help!
Old May 27, 2007 | 03:37 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
well after adjustin g my rocker arms every couple days i realized that one has been backing out causing my rocker arm to appear loose, well it got to the point where the threads got stripped and its almost backed all the way out, i bought a replacement and want to install it but cant figure out how to remove the old one.. they are the pressfit ones not screw in style.. any help would be great, i need to get my car back up and running asap to get to work and such.. thanks
Old May 27, 2007 | 07:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Which threads are stripped, the stud or the nut? If the stud threads are okay, then stack washers under a new nut (non-locking will make the job easier) and pull it out by running the nut against the washers. Add more washers if necessary to get it all the way out.
Is the new one also press-fit? Freezing the stud with dry ice and pushing it in is one way of installing.
If it's screw-in, then pull the head. Machining required (at least cutting threads, depending upon the exact type of stud).
Old May 27, 2007 | 09:35 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: rocker arm stud help!
I don't know the details on your motor but you could be putting more pressure on the pressed in studs than they were designed for.
Old May 28, 2007 | 12:56 PM
stud and nut are stripped, stud not too bad but its deffinately there.. its the pressfit type not screw in.. im gonna go try that washer idea cause the stripped portion isnt till about halfway down the threads.. thanks
Old May 28, 2007 | 07:23 PM
got the old one out, new ones most of the way in, couldnt find dry ice so i froze the stud.. been poundin the crap outta it for awhile needs a good 1/4 - 1/2 before its all the way in.. thanks for the advice about the washers, it helped alot
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
