Need help with Idle Speed!!!
Old May 27, 2007 | 10:46 PM
drummerdude7_13's Avatar
Car: 1991 camaro RS
Engine: 5.0
Hey! I just got my new 91' Camaro RS a little over a week ago and I have been having troubles with the idle speed. The car has a V8 5.0 Engine. When I first start the car for the day the idle speed will be running good at 1000 RPM's but the more I drive it the idle speed goes down to 750 - 500 RPM's and it sometimes will even go up to 1500 RPM's. Does anyone know what could be wrong.
Old May 29, 2007 | 10:45 AM
Car: 1991 camaro RS
Engine: 5.0
Re: Need help with Idle Speed!!!
anybody?
Old May 30, 2007 | 08:20 PM
Silver87's Avatar
Car: 87 T/A
Engine: 305 4BBL
Transmission: 700R
Is it carbureated or fuel injection? Could be a sticking choke or bad choke heater.
Old May 30, 2007 | 08:27 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
it is a TBI
750 is about the norm 500 is low is it a steady idle or does it surge?
do you have a check engine light on?
first i would look and listen for vacuum leaks then i would into cleaning the IAC pintle and oriface
ezobens
Aug 19, 2015 10:29 PM
jbd1969
Aug 17, 2015 07:06 PM
perZ
Aug 15, 2015 01:17 PM
