in line fuel pump??
Old May 29, 2007 | 07:24 PM
92rs365hp's Avatar
Car: 2011 dodge journey
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
in line fuel pump??
I was wondering if there is any way possible to put on an inline fuel pump and actually make it work so you wouldnt have to keep dropping the tank??
Old May 30, 2007 | 03:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Many have done it (although I haven't, personally). You will need to pull out the stock in-tank pump, though. There's a sticky on the Carb forum about modifying the pick-up to eliminate the in-tank pump for an external pump.
Old May 30, 2007 | 08:57 PM
92rs365hp's Avatar
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
Re: in line fuel pump??
ok I will check it out thanks
Glowsock
Jul 24, 2025 03:15 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
