HV oil pump or stock?
Car: 2000 Trans am vert 87 GTA
Engine: 5.7/5.0
Transmission: T56/700R4
Hey im building my 88 350 TPI (L98) and i just got a new set of heads 194 casting and 2.02 intake and 1.6 exhaust, just wanted to know if i should go with a High Volume oil pump or a stock one. also im using an oil cooler that came with the motor, amd im using a stock 5QT oil pan.
please advise. i have herd horror stories about the high volume oil pumps
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: HV oil pump or stock?
If you're rebuilding the bottom end it won't be necessary. The high volume oil pumps put a bigger strain on the distributor gear.
Here's the only scenario where a high volume oil pump is needed:
You have a stock engine with 150,000+ miles on it and when idling hot, the oil pressure drops too low. You don't want to spend the money to rebuild the engine, so you put in a high volume oil pump and sell the car to a sucker.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I don't even use a HV pump in my car. At 7000 rpm, too much oil is in the top end of the engine with a HV pump.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The only real need for a HV pump is if you are feeding a drain on the oil system ie. blower, turbo etc.
It all started back when we used wide clearances on the bearings, that caused massive amounts of oil flying around in the crankcase (=bad).
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Usually if your clearances are stock, higher volume = higher pressure. So you get higher pressure across the board, and hit the pressure relief earlier.
A good use might be if you have added additional volume, ie twin turbos. That way you will have ample pressure across the board with that added volume needed to be oiled.
So yea, stock pump. High pressure spring if you want, that'll keep it from hitting the pressure relief early, so that you can have more oil pressure at the higher RPM's.
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
