Mechanical water temp where to tap in?
Old May 29, 2007 | 06:15 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
So my gauges came today Mechanical everything . So I was wondering what the best place to add the sender to? I want to keep my stock electric gauge. I was thinking since I am not useing either ports on my water neck I could screw the fitting into it? From what I understand it has to be in certain areas. ideas?? Its a carbed 305 stock!
Old May 29, 2007 | 06:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The thermostat housing will only give you engine coolant temp when the thermostat is open. In the cross-over passage would be better.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
m00n420
Sep 11, 2015 02:39 PM
dimented24x7
Sep 6, 2015 03:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
