removing fuel lines from tank lines
Old May 30, 2007 | 09:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
im taking the original fuel lines off my car and have a quick question, i got them all off except the main 3/8 feed line, when i try to disconnect it from the tank hose, fuel keeps coming out and does not seem to want to stop. is there something im missing here? it almost seems to be siphoning out of the tank. the other lines are all off and the fuel cap is loose so there should not be any pressure or anything built up in the tank. help...dont want to burn the garage down or drain my whole tank on the floor
Old May 30, 2007 | 09:34 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Re: removing fuel lines from tank lines
Im not trying to be a smart a** but why wouldnt it pour out? The line is lower than the tank, gravity is going to drain it. Try a golf tee ot a rubber hose over the end with a bolt in it. Smoke outside
Old May 30, 2007 | 09:42 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the lines come out of the top of the fuel tank, then drop and run under the car.
Old May 30, 2007 | 11:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's siphoning out. If you have an air compressor, you can remove the fuel cap, blow air into the line and break the siphon. Otherwise, just drain it out into fuel cans (shouldn't take more than three 5-gal cans).
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
3rdgenparts
Aug 8, 2015 07:09 PM
