missing bad at 3000 and higher!! please help
Old May 31, 2007 | 01:35 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
ok here is some backround. started with a 305 tbi, swapped to a 350 kept the tbi. right now i am running the 350 with the 305 injectors and computer. also switched to a single plane manifold and a luinati cam (458 lift, 218 dur) with stock springs, timing at 8* btdc
ok when i drive it normal it is fine no problems. as soon as i floor it and it reaches 3000 rpm it starts missing bad. almost like valve float. i just installed an air/fuel ratio gauge and at idle it reads rich. when i floor it it goes completely lean...
am i just not getting enough fuel? or is it because of my valve springs?
any ideas or opinions would help me out a lot. i really want to get this thing running good. thanks in advance. -jon
Old May 31, 2007 | 01:44 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: missing bad at 3000 and higher!! please help
I would guess the valve springs. Know how many miles are on them?
But also the fact you're using 305 injectors and computer, with no tuning, and a single plane manifold, aftermarket cam, etc. If it's going lean (how lean?), then it's probably a lean misfire, which is pretty bad.
What heads are on the 350? Like is this a pretty hot engine?
xxx3man`
Sep 23, 2015 10:37 PM
someone972
Aug 30, 2015 12:52 AM
19irocz85
Aug 26, 2015 07:54 PM
Bryan F
Aug 18, 2015 02:28 PM
