what happens in closed loop ?
Old May 30, 2007 | 09:27 PM
89jim's Avatar
My car runs smooth when it is cold.Idle is a bit high, When the engine starts to warm up and the idle starts to drop it runs rough and sometimes stalls. What is happening when these cars go into closed loop? I guess thats what is happening right. Car is 5.7 89 GTA
Old May 31, 2007 | 10:47 PM
scottsz28's Avatar
Re: what happens in closed loop ?
when the car gets into closed loop, the computer starts taking info from the sensors and starts making adjustments to how much fuel is getting sent to the cylinders. so hook her up to a scanner and watch what the computer is seeing. sounds like a senor isnt working like it should
Old May 31, 2007 | 11:23 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
like scottsz28 said, once in closed loop the ECM starts taking feedback from all of the sensors and adjusts timing/fuel/EGR/ect as required.
could be a sensor, wiring or maybe something as simple as a broken ground wire somewhere. Bad grounds can cause some pretty freaking strange stuff!
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
