305 Rough Idle
Old May 31, 2007 | 01:26 AM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Delete
Delete
Old May 31, 2007 | 02:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like a choke issue. Is the choke thermostat wire still hooked up?
What exactly was done with the "carb tuning"?
Old May 31, 2007 | 03:04 PM
camaro87-alex's Avatar
Car: 1987 Chevrolet Camaro SC
Re: 305 Rough Idle
I have same type of car like you with sme engine and everything...Do you have a computercontrolled carb??...Course you have, since you have oxygen sensor.....Then you also have ISC (Idle Speed control) system right??
I am having a lot of trouble with mine...So if that solenoid is wrong adjusted it may cause your idle speed go crazy...
But you have never had this problem on warm engine??...Then it could be something about your choke...And of course theck all you hoses that it is no vacuum leaks...
Old May 31, 2007 | 03:51 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Re: 305 Rough Idle
Delete
westsail42
Carburetors
Nov 19, 2017 11:28 AM
NutmegCT
Carburetors
Jan 20, 2016 11:31 AM
rideon1200
Carburetors
Apr 11, 2006 03:25 PM
Sonix
Carburetors
Feb 20, 2005 06:09 PM
DeLorean247
Carburetors
Aug 8, 2004 04:57 PM
