Burned/Corroded Terminals
Old Jun 3, 2007 | 01:50 PM
mrogers's Avatar
Car: '87 Camaro
Engine: 4.3L V6
Axle/Gears: 3.08
I've had this cap for only 2 years and I just had it off and saw the terminals were blackend and sort of corroded. I could scrape off the residue but they are still black. Car ran fine. It's a MSD cap and I'm also using 8mm MSD wires and AC Delco Platinum plugs if makes any difference. I just wanted to know why this happened and if it might just be a bad cap or if all the MSD caps are bad.
Attached Thumbnails Burned/Corroded Terminals-100_0245.jpg
Old Jun 3, 2007 | 03:09 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Re: Burned/Corroded Terminals
Ionization is what causes it, smear a small amount of dialetric grease on the terminals and the rotor button. I have also heard of drilling a small hole in the cap but go with the grease 1st.
Hotrodboba400
Dec 10, 2019 07:07 PM
J.C. Denton
Sep 21, 2015 04:23 PM
eustodp
Sep 20, 2015 05:09 PM
Denricci22
Sep 18, 2015 09:02 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
