I think i broke my shifter! (automatic)
Old Jun 3, 2007 | 02:20 PM
toomie's Avatar
i removed the **** to put a new plate in , and i had put thew **** back on it doesnt switch out of park, except that it goes to reverse without pressing in the button, but will not move anywhere else.
help please
Old Jun 4, 2007 | 06:56 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: I think i broke my shifter! (automatic)
What new plate did you put in?
You could've broken your cable. Mine somehow got broken. Looked fine but didn't have the travel that it should've had.
Old Jun 4, 2007 | 08:20 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Did you maybe break the plastic rod that goes down through the shifter that releases the lock when the button is pressed?
Give the shifter a little push forward, ill bet it will lock into park then
Old Jun 4, 2007 | 08:58 PM
toomie's Avatar
It was the plastic rod, a piece from the bottom chipped off. thanks for the help
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
