Possible cracked flexplate questions
Old Jun 4, 2007 | 04:52 AM
wackytower's Avatar
Car: 1985 Trans Am
Engine: Superramed 406
Axle/Gears: 10 bolt 3:73
I posted this in the transmission forum but I think it was the wrong place.
I have a tapping noise that sounds sorta like a loose rocker arm but its coming from the TC/ flexplate area. It only does it under load not in nuetral or park. Is this noise something that indicates a broken flexplate? I have done a visual inspection and I cannot see any cracks. The torque converter bolts are tight. Anyone have any ideas? My experience with broken flexplates that they make a terrible sound not just a ticking sound.
Old Jun 4, 2007 | 10:21 AM
BA92GTA's Avatar
Re: Possible cracked flexplate questions
I have broken as many as five flex plates in my life and can tell you they all sounded a little different when they first cracked.
Yes, a slight hair crack will start out with a little tick. All the way to a full spin grinding sound once completly spun.
I know it is a lot to do, but if you really suspect the flex plate go ahead and pull the fly wheel cover get a good light source and check it again for hair line cracks starting at the bolt pattern.
I usually break mine at launch.
Its a little work takes about six hours to replace with just a jack and stands.
Old Jun 4, 2007 | 06:22 PM
wackytower's Avatar
Car: 1985 Trans Am
Thanks I will dig a little deeper
Old Jun 6, 2007 | 04:28 PM
wackytower's Avatar
Car: 1985 Trans Am
Ok I crawled underneath it again today and unbolted the torque converter and spun the engine by hand and I still cant see any visable cracks. However, I did notice if spun the converter by hand watching it go by the mounting pads on the flexplate it is real close to the mounting pads on 2 of the holes but one mounting pad is about 1/8 of an inch away from the converter. could the flexplate be bent making my noise or is this something normal?
Old Jun 6, 2007 | 06:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Stock, or aftermarket torque converter?
Old Jun 6, 2007 | 06:26 PM
wackytower's Avatar
Car: 1985 Trans Am
Its not stock but it is a 2500 stall that my tranny guy got me from his supplier. Its probably a daaco or something like that. The converter spins true.
84z96L31vortec
Aug 20, 2017 12:16 AM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
