distributer difference
Old Jun 4, 2007 | 08:04 AM
Camarothatcould's Avatar
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
recently a fellow member sent me his "primer" that he used on his engines. The distributer itself is from his 89 SBC(L98). He made this dist. to be a oil pump primer. Well, I got it and tried to use it, and it doesn't work on my oil pump :?
Just look at the difference between it and HEI dist...
can somebody clear this up?
Old Jun 4, 2007 | 11:19 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: distributer difference
The oil pump drive shaft should still fit easily into that primer.
Old Jun 4, 2007 | 11:22 AM
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
it does not, its completely different
Old Jun 4, 2007 | 11:30 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The only significant difference is that the distributor gear is tapered around the oil pump drive tang to help locate the oil pump shaft when it's installed. It might take a little effort to get the primer lined up, but it should work fine.
Old Jun 4, 2007 | 11:36 AM
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Nope. I just tried to literally hammer my spare pump shaft into that distributer out of an L98, won't even try to go in, yet with my HEI dist. the pump shaft slide right in. There is definately a difference between the L98 dist, and the HEI one... I'm sure if the HEI one is big block or what, but would that be the difference? The HEI fits my L98 stock pump just fine
db057
Apr 28, 2019 07:45 AM
69GTOby
Apr 18, 2016 02:34 PM
drptop70ss
Oct 4, 2015 09:44 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
