97 vortec specs?
Old Jun 4, 2007 | 03:07 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
97 vortec specs?
hey guys, my camaro has a 97 vortec motor in it that has been converted to carb. I was told it came out of a Hertz rental truck that was rolled. My main question is does anyone know what compression ratio came in these motors and is it a roller motor? Right now I cant see the engine casting number. It does have the 5.7L stamped in it and the heads are 906 vortecs.
also any recommendations for this motor? I was thinking hot cam.
Old Jun 4, 2007 | 03:29 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: 97 vortec specs?
forget the hot cam although it is a very good cam people seem to use the comp grinds more often... and have very good luck. but either way you may need to do some work on them to take that kind of lift... if it hasnt already been done
Old Jun 4, 2007 | 04:02 PM
3rdgenmaro's Avatar
Car: 88 IROC
yeah, the heads will have the work done to them. well aware of their drawbacks. thanks for the cam tip
anyone know the compression ratio and if for sure it is a roller motor?
Old Jun 4, 2007 | 04:07 PM
Car: 91 RS
Engine: 350 vortec
well if it is actually from 97 and is a real vortec engine it is a roller engine probably 9.3 or something :1 not anything super might even be lower or higher if someone has done any modifications
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
wstephan96
Sep 25, 2015 04:28 PM
anesthes
Sep 21, 2015 10:24 AM
