retrofit TPI
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
retrofit TPI
Would it be possible to make a 327 into a tpi? Im just curious seeing as Im building one in the future. Would it give me any gains in gas mileage/performance?
Re: retrofit TPI
Although, I'm going to take a big leap of faith here, and guess that what you really meant to ask was, will TPI fit on a 327; and the answer is, yes. Subject to the center 2 bolt holes on each side of the intake maybe having to be slotted, if the TPI is 87-up and the heads on the 327 are 86-back, or vice-versa.
Sanjay
Aug 12, 2015 03:41 PM
