TPI Flat spot in acceleration
Old Jun 5, 2007 | 03:52 PM
JasonL's Avatar
89 Iroc 5.7..My car was off all winter long. Ran great before I put her away. Now its hard to start. Start it up put it in gear and it will stall until it warms up. Go down the street and there is a flat spot as soon as you push the peddle. Once shes going shes fine and the flat spot clears up. Any ideas anyone. Thanks in advance for any help or ideas.. Also anyone in the cleveland area good at working on these cars?
Old Jun 6, 2007 | 12:59 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: TPI Flat spot in acceleration
sat all winter? i'd bet its just the old gas...run her dry and fill her up. toss in one of those fuel system cleaners if u feel like throwing a couple extra bucks at it.
Old Jun 6, 2007 | 08:05 AM
JasonL's Avatar
I've ran about 6 full tanks of fuel so far and no change. Pulling out of my development today and the car hesitated again. After it warmed up it was fine.
Old Jun 6, 2007 | 08:49 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
No SES light?
Either way, check for codes just to make sure. Not all codes will cause the SES light to come on.
Old Jul 31, 2007 | 03:44 PM
JasonL's Avatar
Well problem was a bad fuel pump. Car should of been over 30 psi and was only producing 15 psi. That would do it. Thanks for everyones help.
stalkier
Dec 6, 2015 11:25 PM
BewleyBizzIROC
Sep 7, 2015 08:05 PM
theurge
Aug 21, 2015 12:46 PM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
