rocker arm studs
Old Jun 5, 2007 | 07:54 PM
FF400's Avatar
Car: formula
Engine: 400 sbc
rocker arm studs
how do you install these and torque them up.. can you torque these?
Old Jun 5, 2007 | 09:32 PM
Vader's Avatar
Re: rocker arm studs
Screwed rocker studs? In iron or aluminum heads?
Old Jun 5, 2007 | 11:06 PM
FF400's Avatar
Car: formula
Engine: 400 sbc
yes, i believe so..
torquer s/r heads. iron
so how do i scew them in tight/torque them?
Old Jun 5, 2007 | 11:10 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
well you could use the lock nut method or there is a special tool for instaling and removing all kinds of studs.. think they even have them at satins a-s-s-w-h-o-l-e....(autobone,pepdweebs)
Old Jun 6, 2007 | 02:15 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'm assuming these are non-collared, like the mrg 76 or whatever it is? Use two nuts locked together, and torque them to 35ft/lbs.
Use thread sealant, like the liquid teflon stuff. Keeps it from pulling oil into the intake ports. Or loctite if you prefer, but be sure it's sealed.
You could probably use a pipe wrench on it too, and just go by feel. I'd prefer this method, since my locked nuts seem to start to tighten down on the stud too easily, and I didn't want to ruin my nice fine threads.
If it's collared, then it's a lot easier eh? It's got wrench flats so...
Old Jun 6, 2007 | 08:24 AM
Vader's Avatar
Originally Posted by Sonix
... just go by feel. I'd prefer this method, since my ... nuts seem to start to tighten...
Way too much personal information...
Strange how some things look out of context, isn't it?
As he mentioned, a hardening thread sealer is a good idea.
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
