BBC heads question
Old Jun 7, 2007 | 06:45 PM
warheart's Avatar
Car: `84 Trans Am, `78 Monte Carlo
Engine: 350 TPI, 454
Transmission: T5, TH350
Axle/Gears: 3.23, 3.42 posi
BBC heads question
Which castings are better for 400-500hp 454 cid big block- 781 or 063 heads. i know that 781´s are open 114cc and 063´s are closed chamber 101cc heads.
thanks
Old Jun 7, 2007 | 07:32 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Re: BBC heads question
The 781's and the 049's seem to be a popular choice for the hp you are looking for.
Old Jun 7, 2007 | 07:34 PM
The 781 has better flow between those 2. It will also work better on pump gas because of the chamber shape.
With 2.19" and 1.88" valves, and a normal bowl port, they'll feed about any street 454 well.
Old Jun 7, 2007 | 08:06 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The open chamber heads for a BBC are always better. It allows for bigger valves and they won't be shrouded. You adjust the compression ratio with a dome piston. Unlike the SBC, a BBC has a different combustion chamber shape and valve design so a dome piston doesn't hurt it.
I was running 781 castings before I upgraded. Bigger valves, upgraded valve train, port work and they work fine. When I punched a hole through one when I dropped a valve, I picked up a set of Merlin heads instead of reworking another 781 casting. I now have a small set of Canfield aluminum heads. They're only 310cc intakes. My engine could benefit with a set of 345cc heads.
MustangBeater20
Oct 29, 2022 09:20 PM
Mickeyruder
Sep 2, 2015 02:45 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
