Backfiring?
Old Jun 8, 2007 | 08:35 AM
shephee's Avatar
Backfiring?
I have a 3rd gen convert that I purchased last year. My wife & I decided to take it on a 400 mile trip to the Smokey Mountains. Own the way I noticed what sounded like the car was backfiring when I lifted off the accelerator.
I thought that maybe I got some bad gas along the way, so at the next fill up I got some octane boost & cleaner and filled it up with premium. This did not fix the problem. At the next fill up I did the same so I guess it wasn't bad gas.
Also after this trip the car has stalled like 3x's while setting at a traffic light. Almost as if the idle is too low. On some of the older cars I have worked on I would simply adjust the distributor to correct this problem but not real sure with this 3rd gen.
I think the prior owner(s) maybe have adjusted the computer possibly but can't say for sure.
Any help or advice on this would be appreciated.
Old Jun 8, 2007 | 08:52 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Backfiring?
I did a little ask.com on Why is my camaro backfiring.....they say its most likely the dizzy that might be to advanced or the carburetor (if you have one) might be OVER-FUELING. I am not sure on the carb as I know nothing about them but the dizzy sounds about right. Check the timing on the car and let us know.
tyeo098
Nov 30, 2015 06:27 PM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
