Code 22.
Old Jun 9, 2007 | 03:59 PM
naterman35's Avatar
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
Code 22.
Ive been having this problem with my 89. Sometimes when i put it in reverse soon after i start it up it will sometimes die and it also sometimes has a hesitation to it... Then also my check engine keeps popping on. So i was at this website (http://sethirdgen.org/dtc.htm) and decided i wasn't going to deal with it anymore id check for codes. Well i got a code 22. Which all it says is Throttle Position Sensor So... I'm not sure what i should be looking at. Am i looking to buy a new one? Or does that mean something else. I just need to be pointed in the right direction.
Old Jun 9, 2007 | 04:55 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: Code 22.
go to tech articles on this site shows how to set tps,this would be the best place start,hope this helps jimmy
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
