Help! LT1 Starter Mod for L98 - Won't disengange!
Old Jun 9, 2007 | 06:11 PM
torqueaddict's Avatar
Car: 89 GTA
Engine: 5.7 ZZ4 Vortec TPI
Transmission: 7004R
I installed a starter for a 96 Corvette LT1 on my L98 GTA.
It starts the car but I don't think the starter disengages since I hear this loud clacking noise while running. To verify this I tried engaging the starter while running and nothing changed.
I have read in many threads that this is a common mod so, any suggestions on what I did wrong?
thanks in advance for any help!
-Dan
Old Jun 9, 2007 | 07:55 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: Help! LT1 Starter Mod for L98 - Won't disengange!
You might have to shim the starter down some. It could be binding from being too close in to flywheel. You can get shims in different thickness. I forget how much clearance you have to have but try looking at about any Chevy repair manual. They pretty much all should be the same clearance.
I haven't had that problem in so long that I forgot the amount.
Maybe someone else can chime in.
Ron
Old Jun 9, 2007 | 11:54 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
just to verify you can shut the car off just fine and the starter doesn't keep trying to spin right? if not then sounds like you need to reshim the thing
Old Jun 10, 2007 | 12:17 PM
Car: 89 GTA
Transmission: 7004R
Thanks! I shimmed the heck out of it and it's great now. The new starter is much easier to put in than that huge OEM one and I like the sound of the gear reduction starter.
Derick15
Sep 17, 2016 05:28 PM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
midge54
Aug 29, 2015 09:51 PM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
