82 T/A Speedometer Question
Old Jun 10, 2007 | 10:23 PM
awadecki's Avatar
Hi everyone--
I have an 82 T/A with 32k original miles on it. I just came back from a 150 mile trip with the car and now the speedometer is having some issues. Instead of the needle moving smoothly, it now moves in a somewhat jerky manner. This is especially true for speeds between 20 and 30 mph.
Before my trip, the speedo worked perfectly. Does my speedometer cable need lubrication or replacement? If so, how would I go about doing that? Do I need to remove the instrument cluster, or can I unplug it at the transmission?
Old Jun 10, 2007 | 10:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Assuming you have cruise control, it could be your cruise governor, which is under the hood. Or, could be the cable(s) need lubing.
If no cruise, or if it's the cable going to the speedo, you need to disconnect from behind the speedo - usually easiest by removing the cluster.
Old Jun 10, 2007 | 10:52 PM
awadecki's Avatar
Re: 82 T/A Speedometer Question
No cruise on my car.
How in the world do I pull the cluster out? This is one of those great interiors with the fake and real torx head bolts. Any tips on cluster removal?
Old Jun 10, 2007 | 11:14 PM
five7kid's Avatar
I've never worked on a 'Bird, so I'll let those more familiar with the particulars answer that one.
Frozer!!!
Jan 19, 2024 04:55 PM
AUZ28
Oct 12, 2015 08:40 AM
AUZ28
Aug 26, 2015 06:08 PM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
redmaroz
Aug 16, 2015 11:40 PM
