Injector confusion
Old Jun 15, 2007 | 08:41 AM
enginecry's Avatar
Car: 89 Formula 350
Injector confusion
My 89 Formula 5.7 TPI won't start without a blast of starting fluid. I've tried all suggestions on this forum so...I'm replacing the fuel pump and injectors. It is basically stock but does have a AFPR.
Stock is 22lb right?
I don't want to change the prom etc. so do I have to use 22lb or can I use the more readily available 24 lb from LT1's without changing the prom?
No Accell after what I've read but which Ford is the right one?
Gracias!
Old Jun 16, 2007 | 07:24 PM
Damon's Avatar
Re: Injector confusion
24s should be fine especially if you have an AFPR to help dial it in (yes, 22 is stock).
92-Formula
Dec 12, 2015 10:34 PM
Jorlain
Oct 8, 2015 01:57 AM
bubbaz28
Sep 18, 2015 02:09 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
