Lunati cam opinions
Old Jun 18, 2007 | 04:33 PM
MR83ta's Avatar
Car: '83 T/A 2003 Grand Am Gt (built)
Axle/Gears: 3.73 posi
Lunati cam opinions
Has anybody used the lunati cams before. I just ordered the lunati vodoo cam and lifter kit and wanted to know how well everyone if anyone liked it.
http://store.summitracing.com/partde...K&autoview=sku
this is the one i got.
Old Jun 20, 2007 | 03:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I haven't, but since no one else has responded. . .
That's a very healthy cam. I hope you have what it will take to support it - heads that will take the lift, intake with a power band that matches the cam power band, a whole lot of stall - just for starters.
Old Jun 20, 2007 | 04:38 PM
MR83ta's Avatar
Re: Lunati cam opinions
well i have full custom heas, valves, springs, rocker arms and studs, a torker intake maniold, pro built 700R4 with 3200 rpm stahl 355cid and hyp. pistons, foged rods and crank. i think i should be ok
Old Jun 20, 2007 | 05:08 PM
five7kid's Avatar
Original Torker, you'll probably be okay. Torker II, you'd be better off with an RPM.
Old Jun 21, 2007 | 12:32 AM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
I just installed the 60123 hyd roller cam http://store.summitracing.com/partde...3&autoview=sku and loving it so far. Still getting things tuned up. Haven't been to the track or dyno yet.
The voodoo line was designed by Harold Brookshire who has been designing cams most of his life. He designed some of the older comp cams line, owned ultradyne racing cams and then designed the voodoo series.
I replaced an ultradyne cam that I was pretty happy with but wanted more cow bell ;-) If you want more info on peoples results with the voodoo line you can check out the Team Chevelle. A lot of people are running various grinds (a lot of BBC) and Harold hangs out and posts there under UDHarold.
Good luck with your build up.
-Schultzy
Old Jun 21, 2007 | 06:11 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I liked my voodoo 60103 for the brief time before I wiped 4 lobes off it.... Nothing wrong with that grind lineup, just know they are very aggressive, so break it in to the letter (and then some).
"Full custom heads" really doesn't mean anything, how about some more info? Torker 1? Oh man, I feel young...
Old Jun 21, 2007 | 10:36 PM
Car: 1989 GTA
Roll with it baby!
-Schultzy
Jorlain
Oct 8, 2015 01:57 AM
88rscamar0
Sep 23, 2015 09:08 PM
Jlanz55
Sep 8, 2015 11:28 PM
john204481
Sep 7, 2015 03:22 PM
TheExaminer
Sep 7, 2015 08:34 AM
