What size o-ring for power steering hose?
Car: 89 IROC-Z
Engine: 383
Does anyone know what size o-ring you need for the high pressure line that goes from the power steering pump into the steering box? I'm assuming both ends use the same size o-ring? Thanks
Car: check
Engine: check
Transmission: check
Re: What size o-ring for power steering hose?
I don't believe the high pressure side uses an O-ring. Just a straight metal to metal seal. This is at both ends, with the fittings torqued to 21 ft/lbs.
RBob.
RBob.
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
My high pressure line used one at both ends. Don't know what size - they came with the new one.
Car: 89 IROC-Z
Engine: 383
My original one had o-rings in it and I know I replaced them last time....but GM couldn't give me an answer so who knows? I'll just find something similar to the mangled one on there now.
I recently walked into NAPA store and asked for those. the guy came back with a plastic assortment box labelled "power steering" we fished out 2 that looked right and they work so far.
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
Just spent an hour searching the 'net for the right o-ring size.
It looks to be a -903 o-ring, you can buy these from mcmaster carr. I would recommend Viton since it can handle the heat better than rubber o-rings.
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
