Hydraulic Roller Lifters?
Old Jun 19, 2007 | 07:58 PM
bluegrass_boy62's Avatar
I have a hydraulic flat tappet cam. I was just wondering if I could use hydraulic roller lifters with that type of cam along with roller rocker arms? I was also wondering if anyone could tell me what kind of cam the 350 Blocks that GM Performance sells take? Any input would be appreciated!!!
Old Jun 19, 2007 | 08:16 PM
Damon's Avatar
Re: Hydraulic Roller Lifters?
No. Flat tappet cams take flat tappet lifters. Period. Roller rockers are OK regardless of what type of cam you are using, however.
GMPP sells quite a few different blocks. Can you be more specific?
Old Jun 19, 2007 | 08:53 PM
I purchased it from Summit... Its a 1st Gen. style block so it has the 1 piece rear main seal and the 4 bolt main, the iron crank shaft, and Im unsure if it takes a the hydraulic flat tappet cam.
Old Jun 19, 2007 | 09:18 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Cam type (hydraulic, roller, flat tappet, whatever) is not dependant upon the block. They make parts to put whatever form of SBC cam into whatever block.
Old Jun 19, 2007 | 09:31 PM
Thanks that helps me out alot.
KO1
16
Oct 15, 2015 05:00 PM
skinny z
Oct 5, 2015 06:23 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
