Engine problems. Engine hesitates alot, and smokes
Old Jun 21, 2007 | 05:29 PM
Clean87's Avatar
Have a problem. Upon start up overnight or after I let the engine cool down the car will smoke just a little, and it hesitates alot when you get bellow 2,300 rpm in almost any gear, it just shakes. Driving on the street in overdrive it tends to shake if I'm not at least half on the thorttle.
Also, I got 300 Miles, on one tank of gas from AZ to CA, and now I'm lucky if I can get 200 miles. Engine has only 117,000 on it and just had an oil change.
Old Jun 21, 2007 | 05:33 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
Re: Engine problems. Engine hesitates alot, and smokes
same problem..sounds like your valve seals are goin..and causing your spark plugs to build up carbon and oil deposits causing misfires...mine has 116,000 miles...i got to chang the spark plugs ever 700 miles...it suxx
Ikes 91Z
Dec 9, 2015 03:49 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
