head/cam swap car running like hell
Old Jun 21, 2007 | 09:01 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I installed brodix IK200 heads and a ZZ4 cam with the mods in my sig and the car has no power. its a total dog! I installed the cam dot to dot on the new timmg chain at top dead center. I used to run 49 psi in fuel pressure but now it ideals best at around 44. It stalls when i have the timing mark on the timing tab. its prob about 20*btdc. It was making a tinny internal backfiring noise but that seems to be gone now. any help would be great. I dont think I have any vac leaks?????????????????????????????????????????????????????????????????????????
Old Jun 21, 2007 | 09:39 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: head/cam swap car running like hell
I have three things that come to mind.
A.) Valves are adjustment is too tight
B.) The distributer timing is off due to not disconnecting the bypass wire for setting the timing. Remove the "Set Timing" connector and adjust the distributer to 6* BTDC with the engine idling and the ECM not controlling the idle.
C.) The ZZ4 cam/200cc head combo is a drastic difference from stock. I feel you need DIY prom tuning to dial in you speed density EFI system. It is most likely running very lean at higher throttle openings and the upper rpms.
Old Jun 22, 2007 | 12:10 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's MAF.
Old Jun 24, 2007 | 12:07 PM
Car: 89 Formula 350
thanks guys.
well I went over the rockers/valves as the car was runing and backed them all off untill they started thicking then tighten them 1/4 turn.
I have been disconnecting the wire for the distributor as adjust timing.
It is possible that the cam heads combo might need alittle much for my current bin.
I was also thinking it could be my MAF, i'm not getting a code for it but the tinny poping noise did go away when i disconnected it? Just dont want to buy a new MAF for $300 if it not the prob??
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
jharrison5
Aug 19, 2015 05:53 PM
Kaweh
Aug 9, 2015 02:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
