Hard vibration with A/C on only
Old Jun 23, 2007 | 05:48 AM
phatkat64's Avatar
Car: 1991 Camaro RS
Engine: L03 305 TBI, nearly stock
Transmission: 700R4, stock
Axle/Gears: 3.23 out of a V6/5 speed car.
At Idle, or between 600-900 RPM, my whole car has a wicked vibration from the A/C compressor. Literally wild! The rear hatch even vibrates!
It's got a R-134A conversion, new orifice tube, new drier, flushed system. 4 ounces of PAG oil, 2.5 lbs R134A.
Turn the A/C off, and it's smooth as silk.
I live in Arizona, driving without it is not an option....
Has this happened to anyone? More importantly, what did you do to fix it!
Old Jun 23, 2007 | 08:09 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Hard vibration with A/C on only
Originally Posted by phatkat64
At Idle, or between 600-900 RPM, my whole car has a wicked vibration from the A/C compressor. Literally wild! The rear hatch even vibrates!...
Check to make sure the harmonic balancer is not loose on the crankshaft or the damper ring has not shed its rubber. Check that the crank pulley is not bent or has missing bolts. Both of these are uncommon.
Old Jun 23, 2007 | 07:23 PM
phatkat64's Avatar
Car: 1991 Camaro RS
The balancer is tight and true....
The vibration is only when the A/C is on.
Old Jun 23, 2007 | 10:15 PM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
I have a similar problem. it vibrated so hard, it cracked the alum tubing manifold coming off the back of the compressor. I suspect it's the clutch, but replacing the clutch costs about the same as replacing the compressor.
I haven't fixed mine yet, kinda strapped for funds, other priorities. on hot days I do suffer but luckily I'm not in AZ.
Old Jun 24, 2007 | 03:32 PM
IROCWPB's Avatar
Car: 88' Camaro IROC-Z
Engine: 383ci TPI
Axle/Gears: stock
mine does it too. it's probably the compressor going. once i had it running and it must've locked up or knocked real real hard because it busted off my power steering pump mount, disabling my car with two chickies riding with me. that was fun.
69GTOby
Apr 18, 2016 02:34 PM
codeysabatini
Nov 10, 2015 04:07 PM
Breazlan
Sep 25, 2015 11:20 AM
InfinityShade
Sep 18, 2015 08:32 PM
Mdenz3
Sep 17, 2015 08:36 AM
