Light discoloration on flywheel surface. Safe to use?
Old Jun 27, 2007 | 12:09 PM
rx7 punk's Avatar
Car: 88 Mazda RX7
Engine: 305- Headers, -680cfm Quadrajet,-flex-a-lite dual fans
Transmission: t5
I had my flywheel resurfaced a year ago and let it sit around. Its not rusted but It does have some slight discoloration on it. Is it safe to use as is? Should I clean it with something? Sand it? Or just use it?
Thanks a ton guys!
Old Jun 27, 2007 | 01:34 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Light discoloration on flywheel surface. Safe to use?
Yea, scrub it with some 180 grit paper in a circular motion as if you were buffing it. That'll clean it off and leave it a bit rough, better for the clutch disc to grab than a glazed surface - just like brake discs. Then spritz it with some brake-kleen and give it a wipe.
Old Jun 27, 2007 | 03:08 PM
rx7 punk's Avatar
Car: 88 Mazda RX7
Transmission: t5
So I can use the flywheel from a 89 305 on my 1st gen GM 350?
Thanks sonix!
Old Jun 27, 2007 | 06:03 PM
Sonix's Avatar
Car: 1982 Trans-Am
Since we're talking about this in your other thread, might as well let this thread die.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 31, 2015 10:31 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Trickskier
Aug 29, 2015 01:12 PM
Omega
Aug 10, 2015 12:46 PM
