Are these lunati rods??
Old Jun 27, 2007 | 06:11 PM
FastEddiesIROC's Avatar
Ok i've got a set of rods out of my 406. But i'm not sure what brand they are. They are defenetly aftermarket rods. They have 7/16 12 point cap bolts with Lunati ARP stamped on them. Now as for the rod it just has a USA and a B1 stamped on one side and thats it. I called Lunati and they said those bolt are made specifically for their rods. The motor was built back around in 95-96, did Lunati not stamp their name in to their rods back then?? Thanks for an input
Old Jun 27, 2007 | 09:47 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Are these lunati rods??
if the bolts say arp and lunati then the bolts were made for lunati ...just like scat's arp hardware says scat on it... probably a safe bet that the rods are also from lunati... the couldnt tell you one way or the other based on the B1 casting?
Old Jun 27, 2007 | 11:33 PM
No, i mentioned the B1 casting a few times and they still didnt say much about it. The way they described the pro mod rod was, one side should have lunati stamped in and on the other side should be a USA and some other numbers or letters but small. Also the sides are real smooth like they were machined. Now for the street race rod they described them to be the exact appearance as a stock sbc rod. Now the rods I have are machined on the sides and are slightly thicker on the beam itself, but what stumps me is if they are lunati rods why isnt their name on them??
Old Jun 27, 2007 | 11:36 PM
Car: 91 RS
Engine: 350 vortec
well are your rods smoothed? maybe weight matching, weight reduction
Old Jun 28, 2007 | 06:00 AM
Just the outside perimerter is.....i'll try to upload a pic of them when i get home from work today
Old Jun 28, 2007 | 10:21 PM
Well here they areEnter away message text here.
Attached Thumbnails Are these lunati rods??-100_0477.jpg   Are these lunati rods??-100_0478.jpg
Old Jun 29, 2007 | 04:40 PM
Car: 91 RS
Engine: 350 vortec
i would say those are lunati rods
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
