simple newbie question...
Old Jul 1, 2007 | 06:16 PM
British Rich's Avatar
Car: 92 Camaro RS
Axle/Gears: Stock
Sorry for being so simple but I bought my first Camaro (92 RS) this week, and plan on doing a full tune up, the usual stuff.
I did do a search for spark plug DIY's etc but nothing came up, surely there are some tune up DIY's on here?
I have done my share of tune ups I just like to read up before I do it, esp as the 4 plugs on the left side look like they have a lot of hoses/wires to move to even get to the plugs.
Any tips or a link to a write up would be greatly appreciated, thanks.
Old Jul 1, 2007 | 10:53 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: simple newbie question...
yes it has been covered millions of time
search harder
TIP#1 jack the car up it will be easier than ripping your arms to shreds from the top
Old Jul 1, 2007 | 11:26 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
hi there welcome to TGO
try through the wheel tub opening, sometimes you can with ratchet extension
but have to remove inner liner and stuff probably
this method works on many makes and models such as s-10 trucks and G bodies and B bodies and so on
but unsure on these cars
probably not though
you will probably have to get very creative and acrobatic with extensions and knuckles and so on
and as far as hoses and tubes go well then youll have to just unplug some and move them
theres no real away around that
a tip to installing plugs is to use a length of vacuum hose that will fit on the ends of the plugs
works really slick to get them back in the holes and threaded in
once you use hose you will do it again in the future and be glad
search feature is disabled on the forums right now and wont be back up for a week or so, maybe longer
good luck
Old Jul 2, 2007 | 09:39 AM
Car: 92 Camaro RS
Axle/Gears: Stock
Thanks - Yeah I have been using the hose trick for plugs for a while, makes it SO much easier getting them back in without ruining the thread.
As for searching on here RS305 I did, believe me, but I am pretty sure it just wasn't working. When no forum showed ANY result for "Spark" "plug" or tune up" I think it's safe to say it wasn't working LOL
I think I'll just get those hoses off and go at it, it can't be any harder than my straight 6 BMW with individual coil packs!!
I am not sure I understand the tip to work from below though?
Do the plugs face down under the cover??
Old Jul 2, 2007 | 10:41 AM
ranone21's Avatar
Car: 1989 Trans Am t-top WS6
Engine: 305 tpi
some of the plugs are easier to get to when the car is lifted and working underneath the car.... I have an 89 w/tpi and it is easier on one in particular to get out... use good jack stands or ramps and stay safe...
Old Jul 2, 2007 | 10:50 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Yes,useing ramps to get underneath makes mine much easier on a couple of plugs.Not haveing emmissions also helps.
Old Jul 2, 2007 | 10:52 AM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
On my L98, I think there's only about 2-3 plugs that I get from the top of the engine (and they're all on the driver's side head). I would daresay it's not even possible to get all of them from the top--at least not without removing a lot of equipment. So I just prepare to spend time under the car when the plugs need to be changed. It's really not that bad.
Oh and Randy's tip about using a small (2"-3") vacuum hose to put the plugs back in saves a LOT of frustration!
Pac J
May 17, 2020 10:44 AM
rubblerubble
Mar 13, 2016 06:57 PM
Rousseau92maro
Feb 1, 2016 05:12 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
mfp189
Sep 27, 2015 09:25 AM
