help with 350 build and hp ranges
Old Jul 2, 2007 | 04:42 PM
1987_Z28's Avatar
Car: 1987 Z28
Engine: 355
Im doing an enginge swap on my 87 z28 and ive been building a 350 for it. Im at the point where im trying to determine just how much power i want. Its going to be a street car that i might take to the strip some day if i get around to it. I want it to be able to run street tires and not have a problem getting traction but if i smash it i wanna spin tires. Some imput on hp ranges and some good head, cam, intake, and carb combos would be much appreciated. Thanks guys
Old Jul 2, 2007 | 06:09 PM
Re: help with 350 build and hp ranges
A good cheeeep combo that seems to work REAL GOOD is flat-tops; Vortec heads with as little work as possible done to them, just new springs and a valve job if possible; a Comp XE262 or XE268 cam, or Lunati Voodoo 262; a Performer RPM; a Holley 750 manual secondary carb or a spreadbore 650 (list # 6210); and about a 2800 RPM stall converter. That's about 375-385 HP that you can drive to work dependably every day. Should cause enough of a traction problem that you'll want LCA reloc brackets.
Old Jul 2, 2007 | 06:36 PM
1987_Z28's Avatar
Car: 1987 Z28
Engine: 355
awesome man thanks the for the advice do you have any idea how much money this will set me back?
Old Jul 2, 2007 | 11:28 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Thats about the same combo I have haha. Unfortunently I am too in the process of doing a 357 swap. I have the flat tops, performer rpm intake, holley 750 double pumper, but I have world product heads, and a diff cam. My setup cost me about 1800-2000 dollars. Not sure if my heads are better than Vortec or not tho.
theshackle
Sep 17, 2020 08:26 AM
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
sreZ28
Aug 14, 2015 07:48 PM
