Threw a Code 35 today
Old Jul 3, 2007 | 12:32 AM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
Just started the car, so it was cold. Temp outside was about 70deg F. I was rolling the car at idle down a gravel alley and the SES came on.Ran the OBD code test and got""35. Idle speed can not be set to desired RPM "What causes this? What do I need to fix? Or is this just a freak one time thing?It's never happened before and nothing changed about the cars performance, no rough idle, no drop in the gauges, nothing....just the SES.Thanks guys!
Old Jul 3, 2007 | 08:06 AM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
Re: Threw a Code 35 today
the book says " code 35- idle speed control- tps sticking or misadjusted, poor electrical connection, open or short in circuit; defective IAC valve, defective ECM". my first suspects would be the IAC or the TPS. then i would check the electrical. ECM failure is unlikely but possible.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
BumpaD82
Feb 26, 2016 02:57 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
64Chief
Sep 12, 2015 08:05 AM
