Help Please!!!
Old Jul 3, 2007 | 11:58 PM
Chitown1818's Avatar
Help Please!!!
Hey guys whats up? let me start out by saying im not new but i cant pinpoint my problem. it is a v6 3.1 mfi in a 92 camaro. ive check my plugs, wires, cap, rotor, oil pressure, and intake. my problem is that when i turn the car on it will run, but it will bog down and wont respond to the throttle. when i drive sometimes it will respond and others it almost seems like it wants to die if i give it gas and when i let off gas or drop it in neutral it runs normal. any ideas of what this problem could be? any input would be great. thanks guys
Old Jul 4, 2007 | 12:10 AM
slackett1's Avatar
Car: 89 TransAm
Engine: 305TPI
Re: Help Please!!!
Plugged cat? Air filter?
Old Jul 4, 2007 | 12:17 AM
Re: Help Please!!!
im not sure about the cat, but i removed the air intake completely and it still ran the same way.
Old Jul 4, 2007 | 12:26 AM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Help Please!!!
did you check your TPS sensor?
Old Jul 4, 2007 | 12:43 AM
Re: Help Please!!!
how do i go about testing the tps sensor?
Old Jul 4, 2007 | 02:00 AM
slackett1's Avatar
Car: 89 TransAm
Engine: 305TPI
Re: Help Please!!!
Make sure your MAF/MAP sensor is plugged in...whichever one you have, I'm not familiar with the v6.
You'll need an Ohm meter to check your TPS
Old Jul 6, 2007 | 03:01 AM
Re: Help Please!!!
ok guys more trouble shooting here. ive replaced the tps sensor, idler air control sensor, o2 sensor, air filter, and all electrical works good. what else could a possiblity bee?
Old Jul 6, 2007 | 10:33 PM
Car: 91 RS
Engine: 350 vortec
Re: Help Please!!!
good that you replaced all those did you set the TPS and the IAC... or just stick them in?
Old Jul 7, 2007 | 03:18 AM
Re: Help Please!!!
i just stuck em in. how do i set them?
Old Jul 7, 2007 | 07:59 AM
Re: Help Please!!!
Sounds to me like it's time to check your fuel pressure, with the gauge taped to the windshield, so you can see what it's doing WHILE IT'S SCREWING UP. That is, just looking at the pressure while it's sitting there idling, may not be enough.
Old Jul 7, 2007 | 04:04 PM
Re: Help Please!!!
the motor will idle no problem, but the second i give it any throttle the motor will bog down like its gonna die and i let off n it goes back to a normal idle.
Old Jul 7, 2007 | 05:15 PM
Re: Help Please!!!
OK, we got that part.
So what's the fuel pressure WHILE IT'S SCREWING UP?
