How to Get to Thermostat on TPI ???
Old Jul 8, 2007 | 08:57 AM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
The intake plenium is directly above the thermostat housing, what is the trick to getting the housing off to change the thermostat, or what needs to come off in order to do so? Thanks
91 Corvette with TPI.
Old Jul 8, 2007 | 09:50 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Re: How to Get to Thermostat on TPI ???
Er... it's been a while... but I'm pretty sure the trick is to unbolt the housing (after doing all the ancillary removal of hoses and such) and remove it.
Old Jul 8, 2007 | 10:01 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
If you can't get to the thermostat housing easy. You can remove the Throttle body to gain easier access. It shouldn't be too hard to get off. The back bolt is the only hidden one. Make sure you don't tear up the throttle body gasket or you will have to buy that one also.
Old Jul 8, 2007 | 01:36 PM
19 z28 92's Avatar
Car: 1992 z28
Engine: carb 355
Transmission: wc T-5
Axle/Gears: 4.11 posi 10 bolt
patience and a flatwrench.....I did it last year and if I remember right, one bolt was easy and the other I had to wiggle a wrench around. You can only turn the bolt a very little bit at time. It takes a while this way but I didn't have to remove anything to get it off.
Old Jul 9, 2007 | 07:32 AM
rick89formula's Avatar
Car: 89 formula 350
Engine: 5.7L (L98)
Transmission: 700R4-(shift kit,corvette servo)
Axle/Gears: borge warner-3.27
I just did mine at the beginning of summer. I had to end up pulling the throttle body off to do it properly. No big deal though. About one hour to complete.
krisner89
Oct 10, 2015 06:03 AM
Wade787b
Sep 29, 2015 01:15 PM
Ducati900ss
Sep 2, 2015 09:05 AM
perZ
Aug 15, 2015 01:17 PM
Sanjay
Aug 12, 2015 03:41 PM
