cranks ,fires ,getting fuel no start
Old Jul 9, 2007 | 07:44 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i don't know whats wrong w/ this car .it has everything new on it (the motor) and it still won't start again. the other day it was running strong,i went back out that night to put it garage and it cranked and cranked but no start.the only thing i physically see wrong is it only sparks yellow at the plugs. i 'm thinking it should be blue.? dist. and all that is brand new.wtf?
Old Jul 9, 2007 | 09:21 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: cranks ,fires ,getting fuel no start
Check your ECM Fuse which should be located by your Battery on the Right Inner Fender..
Then check the rest of your fuses located under the Drivers panel to make sure none are blown.
There is a minimum voltage that your ECM needs to start your car. I am thinking 10.5 but I am not 100% about that number. If it isn't at what ever that min voltage is it will never start. Usually is a bad power wire to the ecm.
Ensure your fuel pump is working and your car is getting the proper fuel pressure.. Should be around 43lbs roughly with Key On engine off
If this engine was just rebuilt.. after you check the above. You might want to look at your Valve's.. Sounds dumb, But it happened to me. They were never set to the proper lash and it wouldn't restart.
Hope this helps.
Old Jul 9, 2007 | 11:02 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
well thats a scary thought .the guy i bought it from said the motor was rebuilt by Jaspers,but he didn't say how long ago. he just told me that it ran well when he parked it. it really started it when i unplug the est it started after that but when it stalled it wouldn't restart and hasn't since. just a few small rumbling through the exhaust. if it is the valves do i loosen them?
Old Jul 10, 2007 | 08:05 AM
battyice's Avatar
Car: 1985 Z28
Engine: 355 topped with Dart heads
Axle/Gears: Stock axle with 3.73's
Check all of your engine-to-body grounds, make sure they are clean and tight. Make sure the the distributor is well grounded and all connections are secure. Have you checked the voltage at the distributor plug? Have you tried a different module?
-If the valve lash was incorrect, the engine either wouldn't run at all or run very poorly. It wouldn't run strong then not at all.
Old Jul 10, 2007 | 08:28 AM
Cflick's Avatar
Car: 87 Suburban 2500
Engine: 455 Wildcat ( somewhat modified ))
Transmission: TH400 ( for now )
Axle/Gears: 4.10 ( for now )
Unless I'm misunderstanding, it sounds like you already know what the problem is !
Pop that module, it'll never start, and set no failure codes because the ECM doesn't know the engine is even cranking.
If it *is* getting fuel, and the spark is even remotely close, it MUST fire, even if it won't run.
Old Jul 10, 2007 | 10:11 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
okay this morning i went and exchanged the whole dist. ( under warranty anyways) so tonight i'll try it and see what happens.then i'll post results.
92camaroJoe
Jul 29, 2023 07:57 PM
bryan623
Mar 22, 2021 06:43 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
