code 32 and on occasion stumble when accelerating
Old Jul 9, 2007 | 11:03 PM
87_gta's Avatar
Car: 87 GTA / 87 IROC-Z
Engine: 350 TPI / 350 TPI
Transmission: 700R4 / 700R4
Axle/Gears: Stock
hey guys i just recently got a code 32 pop up when i took the bird out for a long drive on the high way. then the infamous SES light came on. check it out and it was 32 but when i went to re-start the car it went away light off. it comes back on occasion when i drive her far at about 130km/h. on occasion as well i will slam the gas and it will jump, bog down for a sec the start flying like she should, is this related to an egr problem? this didnt happen before the light came on any help appricated thanks.
87_gta
Old Jul 10, 2007 | 09:22 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Could be an EGR valve problem, or a problem with the sensor in the valve.
Since you get a stumble on occasion, a sticky valve could be the issue.
Old Jul 10, 2007 | 02:11 PM
87_gta's Avatar
Axle/Gears: Stock
Re: code 32 and on occasion stumble when accelerating
how could i test the valve to see if it is faulty?
Old Jul 10, 2007 | 03:03 PM
Ashbrook's Avatar
Car: 1986 IROC
Axle/Gears: 2:73posi
I had the same code 32 with the ses light coming on after driving for awhile. I changed the EGR valve and it went away. I did'nt have the stumble like you were saying though.
Pac J
May 17, 2020 10:44 AM
db057
Jan 10, 2020 08:55 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Lmancha96
Sep 25, 2015 08:11 PM
RedLeader289
Sep 23, 2015 06:50 AM
