squeling pulleys
Old Jul 13, 2007 | 11:40 AM
whits87bird's Avatar
Car: 1987 Firebird
Engine: 305 LG4 lightly modified
squeling pulleys
I installed march underdrive pulleys a while back and they were fine for the first little while, but now they squel all the time. I aligned the water pump pulley with the alternator and crank pulley and checked it with a straight edge and it was slightly better but still loud. I believe it is the water pump pulley that is the problem because there is a lot of shredded rubber on the pump. The water pump pulley wobbles a little bit but it did before with the stock pulleys and they were always quiet. I'm sure it is the alignment because when I spray or water on the belt it gets quiet for a little bit insted of louder like if it were loose. I have read that aluminum pulleys can eat up belts and be impossible to get to be quiet. Is there anything I can do?
Old Jul 13, 2007 | 02:54 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: squeling pulleys
What engine and year of car?
I know on my TPI's there is no "alignment" of any pulleys besides possibly the ps pump. Everything else just gets bolted but the ps pump is a press-on.
Check your belt if you feel your alignment is dead on. You may just need a new one. I've always had problems with "cheap" belts squealing. Now I only get Napa or Goodyear.
Old Jul 14, 2007 | 11:54 AM
Car: 1987 Firebird
its an 87 with a 305
Old Jul 14, 2007 | 08:56 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
It may not be your problem, but what he says is VERY true! The difference between the Kragen Auto type places and a Napa type belt is phenominally better! Nitro
Old Jul 15, 2007 | 09:20 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
TPI?
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
evilstuie
Sep 24, 2015 02:31 AM
