Anyone else have valvecover fitment issues with AFR heads?
Old Jul 18, 2007 | 04:11 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
It's really not a big deal, I had planned on getting some perimeter style covers anyway, but today I was messing with the heads and noticed that the centerbolt covers off my crate motor won't fit my afr 180's with 1.530" springs. Anyone else run into this? I know the springs are larger than stock by quite a bit, but I had no idea. I hope I won't have to modify any other pair of valve covers I get. Thanks
Will
Old Jul 19, 2007 | 03:00 PM
norcalz28's Avatar
Re: Anyone else have valvecover fitment issues with AFR heads?
Anyone?
Old Jul 19, 2007 | 11:58 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Are the covers not bottoming out?
Are the rocker arm tightened down?
Old Jul 20, 2007 | 12:55 AM
norcalz28's Avatar
Each bolt hole on the valve cover has a bracket welded in for support, those are hitting my springs and so is the pcv baffle. I haven't even got any rockers mounted up yet, I was just test fitting. Glad I did.
Will
Old Jul 20, 2007 | 01:18 AM
Guest
Guest
Posts: n/a
Usually its an issue with roller rockers and those braces. You can trim them or maybe just cut them out entirely where they are hitting. The baffle is an issue though, running without some sort of baffle is just asking for oil use... been there, done that. A piece of sheetmetal to block a direct path to the hole will work, if thats an option you'd like to consider.
evilstuie
Jan 9, 2020 08:29 PM
CRFred
Feb 7, 2016 11:39 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
