help car making terrible noise
Old Jul 19, 2007 | 03:33 PM
dantheman9285's Avatar
well my 91 z28 350 tpi has been sitting for a year but started regularly, the alternator went out so i replaced it took it down the road got on it pretty hard, and it took a while to shift but when it did it shifted hard and is now making a loud clanking noise, i thought i spun a bearing or rod, but my dad thinks it isnt, i drained the oil no metal shavings or anything. then i thought it could be the flywheel or torque converter but all that looks good, i cant really pinpoint where its coming from, it idels smooth but doesnt have the power it use to any suggestions. thanks please help
Old Jul 19, 2007 | 03:56 PM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
Re: help car making terrible noise
check the valves
Old Jul 19, 2007 | 04:05 PM
DO YOU JUST TAKE THE VALVE COVERS OFF AND SEE IF ANYTHING IS BROKE OR LOOSE ITS A LOUD NOISE I WISH I NEW HOW TO POST A SOUND CLIP ON HERE
Old Jul 19, 2007 | 04:48 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Is a fast noise or a slow noise, more of a knock or more of a tap?
Hows your oil pressure?
Can you pinpoint exactly where its coming from? Id pull the valve covers and have a look even if your not sure, broken, loose, bent stuff you should be able to tell. Visually inspect first then id start the car and watch the valves move.
Old Jul 19, 2007 | 05:33 PM
alpine247's Avatar
Car: 1988 IROC-Z
yeah just take the valve covers off,u may have a broken valve that is slapping the out hell out of the piston.but im going to break it to u its probably a rod bearing.
also my car is making a hell of a noise to took the valve cover off everything was good.crank the car up have very good oil psi 56lb.so now im going to take the oil pan off and replace the bearings.if the crank isnt bad..
Old Jul 19, 2007 | 06:27 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Its never that easy. If you spun a bearing then the crank probly has to be turned and the rod reworked.
Dan, it could still be your flywheel. When they crack they will make ALOT of noise. They usuraly crack around the crank bolts.
Old Jul 20, 2007 | 05:08 AM
thanks you all for your help, i know how to do basic maintenance but nothing like tearin into the motor, ive reading the archives about the flywheel being cracked guess ill chekc that first, i took the cover off, but i really dont know how to take it off the torque converter is in the way. do i have to take out the tranny to get to it or what?
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
hokis
Aug 9, 2015 03:57 PM
BrianI
Aug 9, 2015 11:52 AM
