Seperating power steering pump from reservoir
Old Jul 20, 2007 | 08:20 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
The parts store didn't have the power steering pump with the reservoir, so I had to buy the one without a new reservoir. So now, how do I remove the pump from the reservoir? The reservoir is that thin sheet metal, I figured hammering on it would destroy it really fast.
Old Jul 20, 2007 | 10:45 PM
chesterfield's Avatar
Car: Pontiac
Re: Seperating power steering pump from reservoir
That's the saginaw p pump, right? (Canned Ham?)
http://www.mattsoldcars.com/techinfo/pspump.shtml
step 6
tap lightly and work your way around.
Old Jul 20, 2007 | 11:58 PM
Sonix's Avatar
Car: 1982 Trans-Am
Hey thanks.
I thought the stud and the nut on the back were cast into the shell - I was wrong. That holds it to the pump!
After removing those, I tapped it gently with a rubber mallet and it came off nice and easy.
I really shoulda gotten a pump with the reservoir, now i'll have a nasty looking reservoir on a nice new pump...
Old Jul 21, 2007 | 12:17 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Haha, let me guess...
Its also got the traditional pry bar cave-in on the side of the res too?
Old Jul 21, 2007 | 12:50 AM
Sonix's Avatar
Car: 1982 Trans-Am
*cough* it does now
Old Jul 21, 2007 | 12:56 AM
Speed Racer's Avatar
Car: '87 Camaro Sport Coupe
Engine: 383
Axle/Gears: Ford 9, Detroit Locker, 35 sp, 4.11
Ha, I hear ya. I'm about to buy a new pump just to get a new reservoir since mine is so beat up. I wish I could just buy the reservoir since the pump works fine.
Old Jul 21, 2007 | 09:43 AM
Car: Pontiac
Sonix, May I recommend an inline filter? I use Cardone 20-FLT2 which can be ordered from Kragen (I don't know what they're called in your area) or probably any other place that carries Cardone products.
http://www.cardone.com/english/club/...%2020-0021.pdf
Its around $20, I started using them to keep hydroboost units clean but it doesn't hurt to keep crap out of the gearbox either.
Old Jul 21, 2007 | 11:27 AM
Sonix's Avatar
Car: 1982 Trans-Am
Apparently GM has the reservoir, at least according to that link. That PS pump is incredibly common, so i'd think it'd be available.
chesterfield - Where does that install, on the soft hose (suction side?) or the high pressure side? Wouldn't that be a tight fit?
I'll see if it's available around here, but I kinda doubt it.
Old Jul 21, 2007 | 03:18 PM
Car: Pontiac
The filter goes in the low pressure return hose. Its made for 3/8" inside dia hose.
Glowsock
Jul 24, 2025 03:15 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
Street Lethal
Aug 12, 2015 11:33 AM
