Timing Questions
Old Jul 21, 2007 | 07:15 PM
Pnormandin's Avatar
Timing Questions
I am hoping to get some advice/suggestions from you guys.
I have an 84 Camaro RS with a 305. I yanked out all the computer garbage and installed edelbrock intake, 600 cfm carb and a Vacuum advance no cpu HEI Distributor.
My question is that my engine wants ALOT of advance. I set it at 6* with the light and it made for a really smooth idle but it feels really sluggish. Should I just keep bumping up the advance until I find the sweet spot?
Thanks in advance. (Ha no pun intended!)
Old Jul 21, 2007 | 07:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Timing Questions
You want the advance all in before 3000 RPM, with about 34 degrees total, give or take a little depending on what your engine likes.
BTW you'd have been better off keeping the stock stuff, it wasn't holding you back at all.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
