Can't get engine to fire up..(long)
Old Jul 21, 2007 | 07:30 PM
AC's Avatar
AC
Car: Used to drive a camaro
Long story. August will be 3 years since I took my car off the road to start this project. I'm nearing the end. I haven't been able to fire my engine up yet to set the timing and begin to tune. I can get it to crank over. I've replaced EVERYTHING except the distributor. Litterally, dizzy rotor and ignition module were the last to get replaced this week. I have my 730 ecm harness repinned to run the $59 code. I've successfully burned a chip and am also able to connect both scannerpro and tunerpro RT to my aldl and both do not indicated any malfuction codes. Just today I had my wife bump my ignition until I felt the #1 cylinder compression start and then rotated the engine over utnil my timing mark lined up with 0deg the dropped my dizzy back in. SO, I thought everything is set. I don't get ANY spark from any of my cap points except when my coil lead is connected to the coil and near my cowl or plenum. I can get anything else, not even a sputter from the engine. I'm looking for ANY input on this. I have tried both my MSD coil and new OEM coil, new acell ignition module and OEM module. My MSD 6AL isn't currently hooked up. I do have 5 autometer guages hooked up. I'm thinking about removing those out of the loop to weed out any potential issues.
Old Jul 22, 2007 | 08:55 AM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: Can't get engine to fire up..(long)
are you sure its ignition related and not fuel?
Old Jul 22, 2007 | 01:59 PM
AC's Avatar
AC
86, I'm concentrating on spark only because I've made sure 100% that I have my dizzy installed correctly and can get spark coming off the coil but not the dizzy leads. When I crank over I think I can actually here my injectors wanting to fire but I could be wrong. I'll go to my ECM injector leads and try the actually injector connects with a test light to see what happens when I try to fire her up. I'm so frustrated because I've litterally spent almost 20k over 3 years to get this far and to be this close......
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
TheExaminer
Aug 26, 2015 04:59 PM
TheExaminer
Aug 19, 2015 10:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
